Old December 25th 2003, 11:37
Hermann Ortlepp Hermann Ortlepp is offline
Exclamation Mercedes brakes
Hi there.
Has anybody tried fitting Merc brakes to a vw. You get realy huge discs on some of the new Mercs (CLK, SL AND S-class), most of them will not fit in wheels smaller than 17", some of them is also cross-drilled for ventilation. You also get the smaller C-class with massive discs (should not be to expensive).
The conversion should be very easy on a type 2, as the PCD on the bolt pattern is the same. The only thing to do, would be to get the right calipers and fabricate the brackets for them.
Should be cheaper than Porsche brakes. You can even get used discs as they get taken off if they are worn more than 1mm per side. I work for Mercedes and we throw them away, as we do not have them resurfaced.
I am going to try a set on my 74 type 2 crew-cab.
I will take some pictures as I go along.
Thanx Hermann.
1962 VW Beetle 2.7 Type4
Type4 powered dragster 320Kw.
Old September 14th 2007, 03:06
alikatcraig alikatcraig is offline
How did you get on with this?
Old March 8th 2008, 08:04
vwcossie vwcossie is offline
I have fitted 330X32 Brembo disc from Mercedes S-class 1999-2005.
Mitsubishi Lancer EVO 8 Bremo 4 pot calipper.
With this caliper you can fit 345 mm discs in 17" wheels
Old March 12th 2008, 00:31
Ever tried this on a bay bus? They look awesome!
Al
