Old December 27th 2003, 09:00
Daggis Daggis is offline
091 gearbox -> 944 Alu arms
Can I use all stock t2 axles and cvs if I do it like this? Will the T2 axles be of the right length?
As I can understand from reading the earlier posts here, the t2 cvs, fit the 944 arms, right?
So if the T2 axles are of the right length this would all bolt up, as far as I can figure at least..
Any opinions are greatly appreciated!
Old December 27th 2003, 13:00
Shadowbug's Avatar
you'll need to use the 944 axles, otherwise you'll be quite short.
a few pics of my project
Old December 27th 2003, 14:45
But the 944 axles will have the correct length?
Old December 27th 2003, 15:23
The alloy arms come in two width, the early alloys being the same width as stock vw and use the same length axles as stock T1, the later alloy arms use longer axles, I believe they are the same lentgh as T2 axles. I haven't measured that so its just hear say. Beware 944 used one shorter axle on their automatics. Do some searching on this forum, this topic as been discussed a few times previously.
