Old January 9th 2004, 09:48
Ian66 Ian66 is offline
Berg 5 conversion....
Hi all,
I'm thinking of converting my gearbox to a 5 speed, but haven't had much luck in locating much reading material about the berg5.
Does anyone have any links to provide me with some food for thought?
Cheers,
Ian.
Old January 9th 2004, 20:19
Alex's Avatar
Alex Alex is offline
Make a search on Berg5 here on Germanlook.com and also over at Shoptalkforums.com .
Lots of info already posted.
Old February 29th 2004, 01:25
ydeardorff ydeardorff is offline
Originally Posted by Ian66
Hi all,
Cheers,
Ian.
The porsche tranny conversion is alot more bullet proof and you still get a 5 speed. check it out
Old February 29th 2004, 13:03
The porsche tranny may be slightly stronger than a type 1 based gear box but there is the cost of maintainance and repair. If you can break a VW tranny chances are you can break a porsche tranny. The only differance is the cost of replacement parts.
Old March 1st 2004, 01:19
true very true! But I have been told it takes alot to beef up the type 1 tranny to make it as strong. not to mention the cool factor of running porsche in your bug. Also the berg 5 I have heard from a former borg warner technition is crap.
For the price to bullet proof a type one tranny you could get two rebuilt porsche trannnies off of ebay, or a junk yard.
Am I right?
Old March 1st 2004, 14:26
I paid $800 for my 4 speed type one and it has everything you could shake a stick at when it comes to performance parts. With the exception of a ribbed case.
Old March 2nd 2004, 20:42
yetibone's Avatar
yetibone yetibone is offline
I'm gonna try the 901 conversion pretty soon. I got the gearbox, a pair of complete 2 litre Type IV's, a DTM, and various other goodies for $1500.
Stock 901's handle 200hp if you don't wind up to 5000 rpm and pop the clutch. They are cheap to buy, but expensive to fix.
I had to convert mine from 914 usage, and make a 901 selector shaft from a 914's and a Bug's.
The only thing I don't like is how the shift rod has to be bent, and lengthened. I'm gonna try and build a 3pc. shift rod assembly with small cardan universal joints, and linear support bearings.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old March 4th 2004, 18:08
vennard vennard is offline
Ive been responsible for starting the porsche vs berg thread in the past. please dont start it again. I ve just decided to stick with the four speed. if this kicks of again Ill end up changing my mind!!!!!
