Old January 20th 2004, 20:53
scottystraub's Avatar
scottystraub scottystraub is offline
944 turbo and non turbo calipers
will 944 turbo calipers fit on non turbo aluminum rear arms? if not is it a easy switch?
Old January 20th 2004, 21:24
From what I understand they will bolt on just fine. I think that you will have to use some washers if you want to run the non-turbo discs to space the calipers correctly. No spacing will be required if you run the turbo discs. Does you trailing arm part number start with 951.***.***. I'm not absolutely certain but I hope this helps.....
Old January 20th 2004, 23:18
great !!!!!!
thanks for the info
