Old February 4th 2004, 12:15
Rob's Avatar
Rob Rob is offline
Seatframe Fabrication
I need to fabricate a sturdy seatframe to mount the slider for my
race seat.
Any engineers here who can help me with some tips ?
I was thinking about making a 'box' out of square tubing, and mount it to the
reinforced space where the original seatmounts are.
For strength I'd mount a bar diagonal across the 'box'.
Hope this is somewhat clear
Any hints/tips are appreciated.
Rob.
Old February 4th 2004, 15:33
Just make sure you have room to sit and put on a helmet incase you ever race it :agree:
Old February 4th 2004, 15:52
Rob's Avatar
Rob Rob is offline
hehehe, no worries. The seat is currently mounted on the stock seatframe, so I know that the height will be ok.
Rob.
Old February 4th 2004, 20:37
super vw super vw is offline
I fabed up a frame for my Porsche seats to mount in a 74 super.
Do a search, there are pics of it some where here.
I have mine made out of 1"/1" square tube and 1"/1" angle and 3/16 plate.
I have a box config whats made out of the angle, then the legs are made from the tubing, and the feet made from the plate.
It mounts in the original seat tracks, and tower aswell as bolts onto the floor pan (But all the weight in suported on the tracks) so there are 7 (yes 7) mounting points for each frame.
One thing i would NOT recomend is making a frame and bolting or welding it directly to the thin floor pan. unless you strengthen it some how, otherwise you might run the risk of having your seats rip out in a crash (no good) not the mention your seats will move around becuase of the thin metal :S(But this wont apply to you as your using the stock tracks to)
Old February 7th 2004, 04:38
thomas_niji thomas_niji is offline
Question
Hey super vw is your beetle a standard or a super?
I am working on my standard and trying to put some new seats in there. I am fabricating my seat bracket, and would appreciate some input on that.
Thanks X 1000
Thomas
Old February 7th 2004, 12:39
Thanks X 1000
Thomas
It's a 74 super... exactly what would you like to know?
Jonathan
Old February 8th 2004, 15:35
Red face
mine is a standard.since i don't have a welder, i will have to build a frame (with steel angles and bolts....) then bolt it down. but now the problem is where should i bolt it to? the stock tracks? i have seen in some posts that say i shouldn't bolt or weld to the floor pan.
Old February 8th 2004, 15:50
I was thinking of using the bottom of my stock seats for the tracks and welding up some tabs on to them to bolt my nissan 240 seats on. That way I wouldn't have to cut any holes in my floor that I just repainted.
Old February 8th 2004, 20:43
Here is what i did.
since you dont have a welder... im not to sure on how you would do this. only thing i can think of if you have no accces to welding is to use the stock seat frames, them modify them to allow seats to bolt on top. but doing so might be the tricky part. maybe add some steel plate that you bolt on that the seats would bolt to... iffy, but might work.
Bolting ONLY to the floor pan is no good, you run the risk of your seats pulling out, and your seats will move due to the flex in the floor pans. so you will need to use the stock tracks some how, or beef up the mounting points on the pan so they dont flex or pull out if you dont use the stock tracks.
there are many ways to do different seats, but a welder or access to one has more options than not... do any friends weld? maybe you can have a local welding/ fab shop do it for you (shouldent cost more than 50 bucks to do JUST the welding)
Old February 9th 2004, 04:28
man your brackets look sturdy!
i am trying to leave my stock seats untouched.....
so that i can sell them if i can put my new seats...
i think what i am gonna do is to cut 2 sections of steel square tubes, and then mount them with bolts perpendicular to the stock tracks
then fab a bracket under the new seats, and mount those brackets onto the steel square tubes......
so it would look like this from the side:
/______\ <- bracket for new seats
D____D <- square tubes
--------- <- stock tracks
sorry for the crappy illustration....
the brackets would be made from 1" square tubes and 1.25" angle and the "sandwich" square tubes would be 1" too. do you think they would be sturdy enough?
thanx thanx
Old February 9th 2004, 11:20
thanx thanx
Hmmm, not sure... You know they do make universal seat tracks for VW's, look in hot VW's or VW trends mag's they are around 60-80 bucks a pop. im not to sure on how they work. all i know is i have seen them and the drivers side has sliders... and the passenger side tilts forward only.
Might be worth investigating.
Jonathan
Old February 9th 2004, 12:09
Rob's Avatar
Rob Rob is offline
I've been thinking alog the same lines.
Since the floor where the original seatframes are mounted is already
reinforced, this should be ok.
Although I 'm still contemplating a crossbar and bolt/weld it to the
heaterchannel and tunnel.
Rob.
thanx thanx
Old February 10th 2004, 01:38
rob,
i have seen posts that talked about that. honestly, if i have a welder, i would no doubt do that. that way i can set the height of my seats at will, and it would be so much easier....
but since i don't have a welder, and i don't want to drill holes into both the heat channel and the tunnel, i think i am stuck with bolting the seats down to the stock tracks.
if you do opt for the crossbar method, please inform us on the difficulty and maybe more importantly the sturdiness of this set-up.
Old February 10th 2004, 03:01
You should look into getting a welder if you are going to make parts for your car. You can pick up a SEARS mig welder for $300. That will take care of most of your welding needs. That's what I have and it is an invaluable tool.
Old February 10th 2004, 04:41
being a college student means that there are other obligations....other needs......
