Old February 5th 2004, 07:01
Dasdubber's Avatar
17in Cup3 52 offset info for b/j s/a set up
Just thought I'd share some info with you regarding my set up thus far. I am using a 68 ball joint swing axle pan mated to a 1963 body. CB performance dropped spindles up front and CB discs front and rear (roto hubs) with short axles.
I haven't mated the body back up with the pan yet but my new Cup 3 turbo twist replicas (52 offset 17x7.5) clear all suspension components up front no problems. Rear is a different story, I can't even bolt the wheels up because they hit the spring plates and cast bump stop. On the rear I will need spacers - I am in the process of sorting out how wide they will have to be. I will also be joining the pan and body soon so I'll update this info then to see if they clear the front gaurds etc.
Alan
