View Poll Results: what to do?
do i part the car out, returning to its stock glory? 4 66.67%
do i sell as is (roller) no motor? 2 33.33%
Voters: 6. You may not vote on this poll
Old February 15th 2004, 04:56
petevw's Avatar
petevw petevw is offline
what to do?
soon my car will no longer have a motor.
here's whats in it:
> Electromotive TEC2 standalone system. (programmable fuel and ignition)
> 96 plate mesa oil cooler
> Trans:
> Built by KSR (Kevin Shull Racecars)
> Dual billet aluminum sidecovers
> 3.88 ring pinion
> chromoly pinion nut
> 3.78X2.06 superbeetle modified mainshaft
> 1.48 3rd
> 1.04 4th
> welded 3-4
> german syncros
> IRS superdiff
> 10 tooth spider gear conversion
> 091 output shafts (super spline drives)
> 091 flanges
> T2 CV's/beetle axles
> Beetle/T2 stub axles
> Solid mounted with tranny straps
> Interior:
> 98 vw golf vr6 seats, modified to fit
> VDO gauges: oil press, oil temp
> autometer procomp 10,000 rpm gauge
> hurst shifter
> sony deck, component speakers,
> kenwood amp
> bazooka tube
> Suspension:
> Front
> Adjust-a-struts modified with honda springs (to fit 17's)
> KYB gas shocks
> sway bar
> Rear
> sway bar
> Tgfab brace
> KYB gas-a-justs
> Brakes:
> european spindles (factory caliper mounts..no
> adapters)
> front cross drilled german discs, studed 4x100
> new flex lines, front & rear
> hurst line-loc roll control
> rear disc brake conversion with e-brake
> rear discs are crossdrilled, studded 4x100
> Exterior:
> H4 headlight conversion.
> True Hella HID H4 conversion, with ballasts and D2R
> bulbs
> Decklid offsets
> T-bar bumpers
'72 super
'65 bus
'52 split
