Old March 1st 2004, 00:09
BWE BWE is offline
Smile March Meeting?
When this month? 2nd? 9th?
Cheers!
Dave
'70 GL Bug, T4 Powered!
www.boxerautogruppe.ca
Old March 1st 2004, 10:07
I can't make it on the 2nd .. have to babysit :agree:
9th I can make it.
Old March 1st 2004, 10:19
Rob's Avatar
Rob Rob is offline
9th is looking good sofar.
Rob.
Old March 1st 2004, 20:56
Alex's Avatar
Alex Alex is offline
I can not make it either day....unless I find a babysitter.
Maybe I can try for the 9th.
Old March 2nd 2004, 01:20
ajracer ajracer is offline
Excitement is Building, Vroom, Vroom
Well things are being to move along nicely, this last weekend my friend and
I re-intalled "my" rebuilt 1641 engine into the beetle. After some extra work
and struggle with bell housing and engine alignment we finally got it right and
together she went. We double checked everything, did a dry run to get oil
pressure up to 20 psi and then called it a day. Tonight after re-installing
the miscellaneous components, removal and re-install the distributor drive
gear and timing set-up we were really. Another check, little gas primer (fire
extingusher nearby) it was time to fire her up.
After a couple of tries and primer we have ignition, and lots of oil smoke since
we well lubricated the cylinders, etc to make sure we were good for start up
and initial brak in. Crank her up and VROOM - VROOM we are in business and
smiling from ear to ear, we did it and she even sounds decent ! (Not that we
were surprises or anything but just been about twenty years since my last
engine rebuild - 327 Chev power).
Looking forward to our next meeting on the 9th. and may even bring along
some pictures or Video clips. There really is light at the end of the tunnel
and it's not a freight train a comin'. See you all soon.
Allan Mayhew (the old guy)
1972 Super
Old March 2nd 2004, 10:34
Rob's Avatar
Rob Rob is offline
Alan,
That's excellent... So you'll be driving for sure this summer !
Rob.
Old March 2nd 2004, 10:37
petevw's Avatar
petevw petevw is offline
i'll be there on the 9th
'72 super
'65 bus
'52 split
Old March 7th 2004, 10:11
Rob's Avatar
Rob Rob is offline
Ales, If you can make it, can you bring that surge tank if you still have it ?
Rob.
Old March 8th 2004, 12:21
CLKWRK's Avatar
CLKWRK CLKWRK is offline
so its the 9th?
GL ghia restoration:
Old March 8th 2004, 13:02
9th it is :agree:
See you all there.
Old March 8th 2004, 17:18
Does anyone have a spare metric brake line coupler they can bring to the meet ? I will have cash in hand, or I'll buy you your beer
I'm looking for a straight coupler ... not the 'Tee'. This is the last item I need to finish my brakes ... don't want to drive to Niagara falls just to pick this small part up ..
Old March 8th 2004, 20:29
Alex's Avatar
I will try to come at about 8-8:30PM.
Old March 8th 2004, 23:08
67ghiaTIV 67ghiaTIV is offline
I won't be able to make it, I finish work at 9:30. Good news is I will be working on the ghia in a week.
Take Care,
Jamie
Old March 9th 2004, 00:26
volksdragon's Avatar
I'm looking for a straight coupler... not the 'Tee'. This is the last item I need to finish my brakes ... don't want to drive to Niagara falls just to pick this small part up ..
i know when i used to work at U.A.P. we carried metric straight couplers.
and at about 2 - 3 bucks. it's worth checkin out.
jeff
Old March 9th 2004, 03:08
petevw's Avatar
crappy tire has both metric and imperial.
'72 super
'65 bus
'52 split
