Old September 17th 2002, 12:23
wacks's Avatar
wacks wacks is offline
Lightbulb which brakes are better?
which is better, a cross-drilled or a slotted disc brake rotor? which works better? is there any difference?
Old September 17th 2002, 19:42
lightning bug's Avatar
Read the "x-drilled, vented or both" thread. I bumped it up for you. I'm just that type of guy.
Julian
'74 Super
Old September 18th 2002, 04:46
bren's Avatar
bren bren is offline
yep.. vented.. crossdrilling is done to allow gas "bubbles" that form between disc and pad during extreme use to escape so the pad isnt lifted way from the disc, and grooving is done so the pads dont glaze up in heavy use.. neither help cooling or efficiency as well as vented discs.
Old September 20th 2002, 11:55
wacks's Avatar
thanks for the reply guys. i'd probably settle for the slotted /groved rotors.
Thanks!!!!!!!!!!!!!
