Old March 12th 2004, 23:33
'74super '74super is offline
sound dampening...
i read one of the tech articles on this site about sound dampening your interior. i know that dynamat is obviously one of the more dominant companies in this area but i was wondering if there were any others out there. i also know that you can buy sheets of sound dampening material for your home at home depot for much cheaper. would these work in the same way as the ones made specifically for auto use? dynamat is a little on the expensive side...and also when applying it do you aplly the whole sheet or just in little strips. in vw trends they did little strips but in the tech artice he just covered everything with it...thanks for the info.
Old March 14th 2004, 20:56
PartsExpress.com and do a search on "dampening". i used the sheets.
Old March 14th 2004, 21:26
I apply it in large sheets. You do not have to cover every inch of the car with it. The object is to stop the viberation, so don't worry about getting it into every nook and cranny.
I would do both sides of the firewall.
Old March 21st 2004, 05:03
gonzojoey gonzojoey is offline
I used some dampening material from http://www.mcmaster.com/ . It's part number 9709T19. It works great! I covered the entire floor, rear compartment, doors and quarters with 3 rolls (with some left over).
Old March 21st 2004, 08:27
Yep, that is the same stuff as www.partsexpress.com sells. It is a little heavy but it works well. It is the same stuff a dynomat less the logo.
Old March 21st 2004, 09:19
Panelfantastic's Avatar
What about the lightweight stuff they list? Anybody tried it to see how it compares to the asphalt based stuff?
There is also a company called B-quiet that offers a product called brown bread (and a full line of other stuff). I bought some, same as Dyna, a little cheaper. Is on ebay.
I'm tempted to buy some of the light stuff just to experiment...
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
