Old March 14th 2004, 05:25
barbe's Avatar
barbe barbe is offline
Wink Type 2
That I can do with a type 2, Ar 1800cc
Vw 1303 superbeetle 1972
Vw T2 Baywindow Panelvan 1972
http://www.networkjava.net
http://www.escarabat.net
Old March 15th 2004, 08:04
barbe's Avatar
help.help for my, motor is 1300 ab i whit change for type 2 ar 1800
Old March 15th 2004, 09:31
What are you putting it in. An exhaust upgrade is always a good place to start. Then carbs and ignition, if you are going to have the case open then a cam/lifter change is in order.
Old March 15th 2004, 09:41
Dave
I think what he is saying is that he has a 1300cc t1 motor and wants to replace it with a 1800cc t4/t2 motor and needs info on how to do it.
Barbe
you are going to need a conversion fan shroud, either a 911 kit or a DTM.
you are also going to need a header from BAS.
other then that, you should probably buy this manual Type 4 conversion manual
