Old March 15th 2004, 22:55
danielzink's Avatar
question on swingaxle 944 brake install....
To those of you that have put 944T Brembos on a swingaxle.
I've been told it's pretty much a "bolt-on".
I've got my backing plates and calipers - the hubs are on the way.
I need a backing plate install kit right ? (big seal that goes in the backing plate and some assorted gaskets where the backing plate bolts to the axle flange).
Then just start unbolting the old stuff and bolting on the new ?
Do use the stock "spacer" that's on the axle ? (big metal one that slides over the splines).
I've heard I may have to mill 15 or so mm off the hubs if I have short axles.
What am I missing ?
what about parking brake cables ?
Thanks, Dan
65 notch 2300cc type4
www.danielzink.com
Old March 25th 2004, 19:02
kafer.chris's Avatar
kafer.chris kafer.chris is offline
use a seal/gasket set for a swing axle beetle all the same as a 944 ..
look at performanceghia.com for the low down ..
reference the spacers i did not use any or so i think but i did not take out any meat on them if i did!!
a bit of a straight swap but hand brake is a little work i cut the ring open on the cable end then welded it when i pushed the pin thru the hole on the brake tensioner thingy...
chris good luck!!!!
Old March 25th 2004, 21:28
danielzink's Avatar
chris good luck!!!!
Since this has been posted I've made some contacts that may help me get this done on a timely basis.
I'm currently working with Lanner from vdubcustoms on the front adaptors and the ebrake cable for the rear.
I'm running a king/link front beam.
Regarding the rears I emailed MBT and got these responses.
No Problem you are wellcome.
If you take a close look to your stock set up you will find a little hole in the ancore plate of the drum brakes on the swing axle set up under the bearing lid. In addition a kind of washer in front of the sealing within the bearing lid has the task to stop transmission oil coming into the drum area. The little whole is a kind of drain for oil comming through. In the past we had a lot of customers and also we ourselves used the 944 aluminium plates for assembling on a swing axle. But sometimes especially on hot days and long fast runs when the transmission oil is very thin it wasn't stop by the single sealing of the 944 plate and poluted the handbrake mechanism. The 944 sealing is the same as the drum brake sealing but in the 944 or the IRS it has only the task to avoid the leackage of grease.
So we manufactured a cast iron plate in the thickness of stock plate where you can use the stock oil barrier set up (:-) including the paper sealings etc. That is our experince due to the missing speed limits we often get problems with the oil temperature of the stock trans boxes. The oil runs out off any whole...
and
Thanks for your interest on our parts. Yes, we have the suitable adapters for link pin front axles, but not in stock. We did it in the past some times but it is not very common in Europe. The cars have normally an automatic pan with standard front and IRS back end.
It is not a big deal for us the only ressource we need is time. We have also aluminium hubs (5/130) for the stock vw or 356 bearings. Do you drive on the rear a swing axle? What kind of anchore plate do you use there. We offer special steel plates for swing axles for usage of the stock lids and bearing set ups to avoid an oil leackage of the gearbox. The anchoreplates out of cast iron can completed with the stock 944 e-brake mechanism and the hub etc..
The prices for the front MBT Kit is Euro 980.- and it contains the adapters for the stock spindles, hubs and hardware. The plates for the rear cost Euro 248,- each. The delivery time is in the range of 4-6 weeks.
We prefer pre payment of about 30% with the start of the project and the rest after finishing the work before shipping in the U.S..
By the way our recommandation is not to use the 944T- set up. Due to the different weight distribution of the 944 transaxle car in comparision to our beetles the 911 set ups like the 964 (same body design as the 944) are the more better choice. The 944-set up tends to block the front axles especially on slippery roads....
I don't think I'll have a problem with the rears leaking - I'm sure they're talking about extended 100mph runs on the Autobahn that I'll never see.
I'm still going to run the 944t dual pot Brembos and see if maybe I need a proportioning valve for the fronts.
I'll post as the project goes along.
I hope to have my front end parts off to Lanner by Monday (3-29) for machining and fitting.
I need to have this car on the ground (with the Brembos on it) by the 2nd week in May for my first show.
I'll post pictures !!
Dan
www.danielzink.com
Old March 25th 2004, 22:10
VDUBCustoms made my front drakes. They are the 944-S brake kit featured on their website. I should have my brakes back in two weeks at the latest...
Old May 2nd 2004, 22:51
danielzink's Avatar
I'm getting closer to getting htis all bolted up.
I did a trial fit on the rears today.
One problem.
It seems the 944 aluminum backing plates don't want to "snug up" to the flange on the axle tube.
It seems there's about an 80 thou. gap there.
I think I can get the backing plate machined and also the spacer in front of the bearing.
Just wondering if anyone else has had this problem ?
Thanks, Dan
www.danielzink.com
Old May 2nd 2004, 23:58
Isn't there a paper gasket that goes there for the original backing plate.
That might take up the gap...
Old May 3rd 2004, 07:59
danielzink's Avatar
no way.....
I'd need about 30 paper gaskets to make up the gap....
I may have to have the backing plate machined.
Dan
www.danielzink.com
Old July 14th 2005, 23:08
63Rag 63Rag is offline
swing axle delima
Fellow Glookers,
The solution will probably be as follows Atatched pics:
Pic 08, the backing plate cover/seal Machine down the size of the actual backing plate thickness. it is only a few mm's. Or shave off all backing plate sheet metal and hardware (seems tough) then bolt on the porsche backing plate
Pic 03, shows actual porsche caliper mount/backing plate.
Pic 07 shows hub machined down. picture is deceptive, the ring that holds the actual disc is still intact. I think I will probably ship my king pin front cb spindles to Canada. They seem to know what there doing at http://www.volkszone.com
Koo ro ku ku ku rooo ku ku.
Ill send more pics when avail.
Ralph
Old July 14th 2005, 23:26
danielzink's Avatar
Actually - the solution was to find the proper backing plates.
I found a few sets of these backing plates and bought 'em up.
They fit perfectly and work with the stock vw bearing cap and gaskets.
Dan
www.danielzink.com
Old July 15th 2005, 02:54
Yes! 944 swing axle solution!
Eureka!
Im a little bumed that they dont apear to be aluminum. But hey they work.
What year model are the off of. I have the hanes manuel and I didnt see this set up. Im off to the boneyard to see if I can score them.
Thanks, fello GL's.
Ralph
Old August 1st 2005, 19:35
MattKab's Avatar
MattKab MattKab is offline
Good call Dan,
When I was buying my brakes at Porschapart, I remember seeing a backing plate that was genuine and fabricated out of machined and pressed steel. It looked interchangable with the cast part in the pics, when compared side by side. 924S?
Matt
Old August 1st 2005, 23:12
danielzink's Avatar
Originally Posted by MattKab
Good call Dan,
Matt
The crazy thing is that they have the same part number on them as an aluminum 944 backing plate (standard style).
MBT has them but they're spendy.
I thought I had another set hiding - as I bought a few sets at the time. But it looks like I don't.
I've called every Porsche breaking yard across the US and no one has them.
They're off an early early n/a 944 if I remember correctly.
Dan
www.danielzink.com
