Old March 31st 2004, 23:36
Brad Brad is offline
Last minute wheel fitment question...help please
I have a 73 super and I've been in the process of putting Porsche wheels for way too long now. The time has come.
-I have CCC 3" wider fenders in the rear.
-The rear wheels are 17 x 9 ET55.
-I'm using a 1.5" spacer, CSP drums and EMPI coil over shocks.
Will I need to grind on anything for clearance etc?
Baby Blue '73 1303
BrassMonkeySG@aol.com
Old April 1st 2004, 08:58
you shouldnt have to with that 1.5" spacer.
also, what are you using for brakes in the rear?
Old April 1st 2004, 10:17
CSP drums at 5 x 130mm
Baby Blue '73 1303
Old April 1st 2004, 10:30
you should be fine
Old April 1st 2004, 15:27
Thats what I needed to hear. Thanks man.
Baby Blue '73 1303
Old April 1st 2004, 22:28
Superman
You sould be okay *with the spacer* because the 17x7.5 ET52 & 17x7 ET55 just fit within the car therefore at the same offset + 2" would be too wide, based on these other sizes.
