Old April 12th 2004, 13:13
super vw super vw is offline
Question 944 sway bar instalation ?
On my 74 super beetle im trying to mount a early 944 sway bar.
I know i have to make some mounting brakets (will be using modifiyed 944 units)
My question is do i need to make the "arms" on the sway bars paralel to the swing plates to have correct geometry? aswell as having the drop links totaly vertical? or does it not matter?
Maybe some one can show what they did with there 944 sway bars ?
Thanks!
Jonathan
Old April 12th 2004, 21:23
If I can get to the store tonight I will buy a digital camera and take some pictures of my setup for you. I'm pretty sure that I had the links vertical with the suspension fully compressed or have way compressed. I can't remember right now but when I put the suspension back on this week I will let you know.
Old April 12th 2004, 21:27
Nice... what would be great!
Having a digital camera now a days is very usfull, and fun!
Old June 6th 2004, 13:54
LOAF's Avatar
LOAF LOAF is offline
BG
Was curious if you ever got shots of your sway bar set up..
Are you using the wide alumn arms.. with an early or late 944 swaybar..
From the other springplate pics seems like you fabbed some brackets to mount the bar to the arms.. what about the torsion bar housing.. did you cut and weld the 944 brackets to the beetle torsion bar tube..
ALex
also a
Old June 6th 2004, 14:23
Originally Posted by LOAF
BG
ALex
I am using the late aluminum arms. I used some 1" square tubing to make the sway-bar mounts. I than used some plate steel to build up the bushing seating surface. I tham simply ordered the stock 944 bushing clamps and hardware. Here are a few pics...
Old June 6th 2004, 15:35
LOAF's Avatar
GTG..
Thanks that was fast..
I have some more questions that are related.. but I will keep them on their original posts..
also a
Old June 6th 2004, 16:40
i cut the mounting tabs off a 944 beam then added some 3/16x2" plate steel to the tabs, then welded the tabs to the beetle beam. I like the way BG did it, looks good. A little more fabrication involved though, looks like he had to drill/tap the mounting holes.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old June 7th 2004, 22:09
LOAF's Avatar
Thanks for the help..
Lot of options to consider in doing this..
I have a subaru WRX front and rear swaybar in my basement.. different sizes and shapes so I will see if I could some how use these on the vert.. If they are narrow enough I may be able to fab something like BG and adapt these..
It is always better to use free stuff, if you now what I mean..and the size is about 19mm or so, so it should be in the ball park..
We will see..
also a
Old June 7th 2004, 22:58
Mikey 1972GL Mikey 1972GL is offline
I just saw the pictures today, the mounts look cool :agree: that's a cool way you made them, with 1" square tubing. I can't wait to see the whole thing together... keep up the good work.
Mike
My new user name, Mikey
for some reason, I havn't liked this name since I made it.
Sorry for any problems... Mike
Old June 8th 2004, 10:27
Where can I get those shackles? Pelicanparts are US$75+ each! I just need those!
T4 2666 1303s
Old June 8th 2004, 19:01
I got mine off of e-bay with the bushings and sway bar for $35 shipped...
Old June 8th 2004, 20:34
We will see..
You will need the 944 shackles to be able to adjust the camber of the rear suspension. If you can make the WRX bars fit the 944 shackles then go for it.
