Old September 20th 2002, 12:29
wacks's Avatar
wacks wacks is offline
Talking Rack and pinion for standard beetle
has anybody here done a rack and pinion conversion for a standard beetle? i am planning do a conversion on my car. if possible what r and p should i use. thanks
Old September 24th 2002, 20:34
Im fitted one from a 1303 to a 1302 buts thats no use to you.
Things to look out for, make sure it turns the right way, when you turn the streeing wheel right, it turns right. Look for one off a car that has the the steering knuckles at the rear of the stub axles. Also look for one that is similar to the 1303 / Passat rack, it has really long tie rods that start almost in the middle of the rack, avoid one that have stubby arms at each end, you will get less bump steer with the one with long arms.
Steve C
Old October 14th 2002, 18:59
mr.cookiecutter's Avatar
mr.cookiecutter mr.cookiecutter is offline
Cool
Hi Wilson!, maybe you could use one from a japanese car.
I have seen one, and he used one from a Kia car. and it handles fine.
