Old April 14th 2004, 08:26
Bad bug's Avatar
Bad bug Bad bug is offline
Big red calipers on stock vw bug disk
Hi guy's can the red caliper be used with the stock vw bug disk rotor. What's the size of the stock vw bug rotor.
Old April 14th 2004, 17:35
if you are referring to porsche's big red calipers, then no. you will need to use porsche rotors or one of the same dimensions. i don't have dimensions handy, but they are not even remotely close to being the same. about twice the thickness difference.
Old April 15th 2004, 02:09
993 tt rotor dimensions, 332mm x 32mm.
T4 2666 1303s
