Old April 14th 2004, 16:17
steven erwin steven erwin is offline
Question Rear Calipers
Do All Porcshe Rear Calipers Have The Same Mounting Holes? For Exp.will 1989- 94 C2 Rear Calipers Fit On My 1983 944 Caliper Brackets Correctly? Thanks For Your Time!!!!!!!!
Old April 14th 2004, 17:32
Superman
The 924 and 944 have a 94mm bolt pattern. This pattern is also used on the late 90's model 911 and the 928. This pertains to the rear, the front is a whole 'nother story. Also, some calipers have different offsets and may need to be centered. What has been proven to work best on our Bugs are the 944 calipers.
Old April 17th 2004, 23:33
THANKS FOR THE INFO....
