Old April 18th 2004, 19:20
super vw super vw is offline
will 944 drive shafts...
Ok, so i have all the 944 brakes bolted up, i have the 944 stub axles, and i have some 944 drive shafts that i want to use (100mm CV joints). i noticed the 944 axles i have are a little shorter (maybe 1/2 inch) than the stock drive shafts. Will this be a problem? I assume the type 181 (VW Thing) output flanges are the ticket to doing this swap?
The only concerns i had was the length of the 944 driveshafts i have.
Thanks!
Jonathan
Old April 18th 2004, 23:37
I had a set of type 181 drive flanges and they stuck out farther than the type 1 drive flanges by about 1/2" to 3/4" so you should be fine. I 'm not 100% certian about the distance but maybe someone that has a set laying around could measure them for you.
Old April 18th 2004, 23:39
sweet, i looked at the 944 units compaired to the beetle ones again and it realy is only about 1/4 shorter.
Thanks for the reply, you wouldent happen to have those output flanges and want to sell them would ya?
Later,
Jonathan
Old April 18th 2004, 23:42
Sold them already. Sorry.
Old April 19th 2004, 00:56
No problem... im sure some one on The Samba would have some. or i could get them from the thing shop.
