Old April 18th 2004, 20:16
VRSICK VRSICK is offline
Watercooling your aircooled...
I am planning on putting in a wbx engine in my 70, and wanted to know if anyone here has ever done an engine swap, other than air-cooled, and can help me out wit hthe rad. I'm looking for info like, what rad to use, what sizes, how to mount it, where do you run the piping, etc. Any help would be great!
Thanx a mil
-Mike :agree:
Making my 70 Beetle into a GL
Old April 18th 2004, 20:32
Rob's Avatar
Rob Rob is offline
Mike,
Check out my trials and tribulations at http://www.vanbran.com/bug/conversion1.htm
Also make sure to check the work from Panelfantastic !
There are many engines you can use, I am not sure that a WBX is the best choice. A lot of Vanagon owners swap these out for Subaru or other engines.
Usually the rad is placed in the front, running the pipes either through the passenger compt or under the floorpan. As to the size of the rad, use the same size (or bigger) than the rad that came originally with the engine. Chances are that airflow will be less than in the original car, so you will need at least the same size.
Hope this helps,
Rob.
Old April 21st 2004, 07:51
I fitted a WBX in 1988. http://www.clubvw.org.au/steve.htm
Steve C
Old April 21st 2004, 10:23
Rob's Avatar
Rob Rob is offline
Wow Steve, that is an awesome car !
I like the bracing you did for the framehorns. That's an excellent idea !
Rob.
Old April 22nd 2004, 17:32
cormac163 cormac163 is offline
nice threads
check out the thread "and so it begins.... "
:agree: cormac
Old April 25th 2004, 22:47
ya see, the whole idea of this project was to keep it VW. I'd like to fit a watercooled, vw engine (from ANY car), into my 70, and actually make it kick some tail. The only 2 engine's that i've found that can fit in the bug, while still closing the deck lid, is the wbx, and the 8v from a rabbit. The wbx just "seemed" as if it would be more fit to go in the bug, since its an opposed 4 cylinder engine, and has pretty much the same make up of a type 1, or type 4. I don't soppose any of you have any experience or links to sites that have any info on doing an 8v conversion, or have any other VW watercooled engine that would fit in the back of my 70???
thanx for the replies
-Mike :agree:
Old April 25th 2004, 23:50
I saw a picture of a 1.8T fwd setup placed mid mounted in a beetle. Basicly someone took the front drivetrain and placed it in the rear of a beetle. The engine is where the firewall used to be. Its all VW
Old April 26th 2004, 00:41
beesquad711 beesquad711 is offline
Location: California (Southern for school, northern for summer)
SHOW ME!!!!!
Brandon E.
1971 Baja
1972 soon (or maybe not so soon) to be GL 1302
Old April 26th 2004, 07:55
Rob's Avatar
Rob Rob is offline
Superman runs a GTi engine in a Super. Check his profile.
Rob.
Old April 26th 2004, 09:51
Hi Rob
Thanks for that, I think a Kafercup brace do a good job as well.
Im pretty sure Superman used a whaletail so he could fit the Golf motor in.
Steve C
Old April 26th 2004, 16:52
Yes, i've seen that 1.8t setup many times, but I am not THAT experienced with cars, especially beetles. That looks as if it will take a MAJOR undertaking, and way out of my abilities. I was looking for something that I could fit in the rear, and bolt up to the tranny (Using an adaptor if needed)
Steve, do you know if he needed that whale tail to fit the gti engine? if he can fit that, i wonder how difficult it would be to, say, put a g60 engine in there. Where can I find whale tails anyway? I know that i've seen them at creative car craft, and i heard through the grape vine that carbonjoe.net WAS making one, but now his site is down for an unknown time.
Old April 26th 2004, 20:50
Originally Posted by beesquad711
SHOW ME!!!!!
I can't remember where I saw it.
Old April 28th 2004, 07:11
Rob's Avatar
Rob Rob is offline
In case you are still looking for a WBX:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Rob.
Old April 29th 2004, 09:31
Bobtail is building it for a customer:
http://www.centralvwaudi.com/Beetproj.htm
Old May 11th 2004, 17:40
Ribz's Avatar
Ribz Ribz is offline
bunch of swaps here http://frost.bbboy.net/vwengineconversions
ill be starting my swap as soon as my engine and trans arrive, within a week or two, acura v6 with an 091 trans with probably an arm setup in the front so i have lots of time to figure out wiring, luckily i live in wires all day long, with pretty much unlimited access to an acura dealer, what the hell right, ive done more stupid things about 245hp stock, all i want is 300 even this is for my baja, G-style very soon, just have to figure some things out
BTW *waves* im new here hello
