Old April 19th 2004, 22:57
SuperRSi's Avatar
SuperRSi SuperRSi is offline
MBT Uniballs trial fitting
Got the MBT Uniballs on for trial fitting. They are very nice. Check out the clearance on the rear 11 inch wheels with 295/18 tires. This is without running any spacers. Now waiting for the 14mm to 12mm bolts I just ordered. It's always something. But I am excited that it is about to be a roller in a couple weeks. Then on to fitting the RS steering rack, Tilton pedals etc.
Old April 20th 2004, 09:28
What are you doing for strength since you've got no torsion bar?
T4 2666 1303s
Old April 20th 2004, 12:10
SuperRSi's Avatar
I don't know where the attached pictures I uploaded went? Because this is a tube frame car we will build a tube frame version of a Cup brace in the rear and will connect the front shock attachment points to each other with a front tube that will also hang the RS steering rack. The projected tubes will include Nascar type door bars under the side pod. We are calling those a part of the SUV bar system. Something that I didn't worry about when I built my first Manx in 1970. Got the tube bender out yesterday and started drawing the system on a napkin to reproduce. I put some new pictures on the member profile including one of my non-Manx...
Randy
