Old April 21st 2004, 16:26
1986 944 front struts spindles rear suspension
i have a 59 split bus
i had to buy all 4 corners from this car
i only need the front and rear calipers
plus the front hubs/discs.
i have a 944 turbo rear set up from a 86 car
and i wish to swap it for the earlier upto 85.5 setup-steel arms
seperate caliper mount - disc hub
i'll also give you the rear anti roll bar
and maybe the front legs and spindles-they take twin-pots ie 94mm on centres
or i will sell what i don't require for the current market price for the stuff i need minus 30 percent
thanks
i am in west london
thank you
oh i also have a 15 by 5.5 et 53 steel wheel - which now wont fit over the twinpots!!!
Old April 22nd 2004, 13:56
Pillow's Avatar
Pillow Pillow is offline
Yup the 15" wheels will not work with the Turbo brakes. You must go 16s or even better 17s.
Good luck in swapping as these are good brake parts!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old April 22nd 2004, 17:32
aint it a pain in the butt
ive now soursed 2 17 by 7 twists
i want 2 more
this site is cool by the way
its just a shame u guys are over the pond!
another question
can i use this hub-remove the spacer get shorter studs-bay?
and new discs?
Old May 6th 2004, 18:37
for sale 9 by 17 twists- tyres
and the late 944 suspension
300 pounds
or swap for early 944
and 7's
07748582044
