Old April 23rd 2004, 15:45
944 turbo rear in a splitty
I have had the spring plates modified for irs
i have some type 4 drive shafts 17 ins
the question is- can i use bug irs a arms and cv's and splined shafts
in these hubs, then get some 944 or aftermarket caliper mounts?
i intend on using twin pots upfront on a splitty
where in the world can i get some front caliper mounts?
thanks
Old May 3rd 2004, 21:33
Shadowbug's Avatar
its been sone with the 944 allot arms, but he had to disassemble the rear suspension to change the tires.
a few pics of my project
Old May 6th 2004, 18:41
Question was he using 9 inch wheels or 7's?
i'm getting there - i think!
Old May 7th 2004, 22:28
Pillow's Avatar
Pillow Pillow is offline
Call up Russell at Old Speed (www.oldspeed.com) for the front fitment of 944 brakes. It is very easy!
On the rear I have no idea what ride height you want so it is hard to answer that question.
I am running a little bit of the Old Speed kit (modified swing plates) and then the Bus Boys adjustable control arm mounts. The Bus Boys clamps are the only way to go in my opinion. T1 IRS arms with 944 stub axles, Thing output flanges on the tranny, SAW floating axles, and T2 CVs.
With my setup I am staying at stock hieght and running 15" Phone Dials. No problem getting the wheels off the rear. But with Turbo brakes you need at least 16" wheels... If you drop it expect tire removal issues.
My issue now is upper shock mounting brackets... Grrr!
Good Luck,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 9th 2004, 00:43
Bullyboy Bullyboy is offline
Creative engineering makes them, bolt on or weld them.
http://www.creative-engineering.com/...=7661390_12258
I really like their IRS system exept, I have to find a 68-69 bus to yank the bits off of.
Old May 11th 2004, 04:39
paul_f's Avatar
paul_f paul_f is offline
Pillow,
Use Russ's top shock mounts - or if you have a lathe make your own. They are a piece of 20mm round stock about 25mm in length and tapped in the centre which you weld to the underside of the chassis rail, where the u shaped support is. I then used Mini front shocks due to the reduced distance.
Anything else will knock the bushes out of the shocks rapidly
Russ doesn't charge a lot for these
Paul
Old May 12th 2004, 18:38
MattKab's Avatar
MattKab MattKab is offline
Paul F, what shox are you using?
Matt
Old May 12th 2004, 18:56
paul_f's Avatar
Some Gabriel Red rider austin mini front shocks. Apparently they are 50% uprated - I got mine for 10 quid each from Brown Brothers - some guys on a mini forum recommended them. I removed the steel insert from the bushes and then pressed in the ones I had removed from the beetle rear cofaps I had previously.
Paul
Old May 13th 2004, 15:26
MattKab's Avatar
Thumbs up
Thanks for the tip.. I'm helping a mate gather parts for a low IRS '66 Bus, may have some more Splitty questions...
Matt
Old May 14th 2004, 13:28
paul_f's Avatar
No problem, I recommend you speak to Oldspeed for the sway awat driveshafts cheap cheap!
Old May 14th 2004, 17:38
MattKab's Avatar
T3D supplied the '68/'69 parts, along with a pair stock T2 driveshafts, is there an issue with the length, did I hear?
Matt
Old May 14th 2004, 19:40
paul_f's Avatar
Oh if you are not running 944 rear then its not too bad, very low though and they are too long and the CVs will get knocked out quickly, as will the grease seals on the output flanges from the box, therefore soaking the CVs in oil.
Old May 25th 2004, 23:23
Pillow's Avatar
Thanks Paul. I have the Old Speed shock mounts... Just no idea where to weld them on. DOH! If you have an installed picture of yours that would be a great help.
Take Care,
Adrian Pillow
