Old April 25th 2004, 20:40
72blacksuper 72blacksuper is offline
parts that need installed.
does any one else have a huge list of parts waiting to be installed like me? If so post what you have to install. I need to put in my porsche bucket seats, porsche steering wheel, window seals, cd player, speakers, subs, amps, carpet kit, rims & tires, horn, new wiring kit, exaust, body rubber, headliner, alarm, and a few other random things. I bought it all now I just need to find the time to put it all in or on.
Peace,
Wil
Old April 25th 2004, 20:58
Here is all I can think of.
rear trailing arms, again.
front and rear brake lines.
master cylinder.
transmission.
kafer cup brace, again.
front brake kit, again.
steering parts.
shifter and shift rod.
e-brake cables once I make them.
rear suspension, again.
brake pedal aasembly.
clutch cable.
drive axles.
It's a never ending battle.
Old April 25th 2004, 22:28
901 gearbox/shifter
Old April 25th 2004, 23:45
Originally Posted by NO_H2O
901 gearbox/shifter
Such a short list... I envy you.
Old April 26th 2004, 08:12
Ok, a 2275 type 1 also.
My list was long at one time but i have done most of it.
Old April 26th 2004, 09:37
LOAF's Avatar
LOAF LOAF is offline
I am so far behind..
I have topline Struts for the front assembled and attached to the A-arms which are off the Bug.. The 944 swap is done and also attached to the arms.. That is just sitting on bench awaiting the rest..
Still have my 944 rear trailing arms to dismantle... rebuild and transfer to the bug.. Then figure out the whole e-brake, and master cylinder deal..
Lets see..Have a bunch of body parts to put on.. but thats after I take the body off the vert and do the floor pans..
Still have to figure out Type I or IV, and if 4 speed or 5...
I am so behind.. On a good note I did get my other car ready for the track so no I can shift focus back to the vert...
Oh yeah almost forgot my design 90's need to get checked for trueness, and then powercoated satin black.. prbably more stuff but that all I want to remember..
also a
Old April 26th 2004, 09:43
Rob's Avatar
Rob Rob is offline
- Create and install radiator shroud
- Lexan quarter windows with naca ducts
- ECU
- Wiring of ECU and power circuit
- Seat
- Exhaust
- radiator hoses
- Finish air intake
- Modify rear fenders so they clear the engine
- Create / modify rear apron
- raise front suspension
- install fuel pump
- install fuel return line
- Did I mention wiring ?
Rob.
Old April 26th 2004, 20:39
FINALLY my list is much, much shorter.
engine, again
cup brace
shocks, again
redo oil cooling
wire rest of alarm and door poppers
rest of stereo install
front and rear sway bar
exhaust
and i think that is pretty much it. 4 or 5 years to get to that though. technically 10, but i only like to count the years i actually worked on it.
