Old May 4th 2004, 16:39
brakes dieing help
ok so my brakes are dieing and i want to upgrade just a little. disc only in the front as my car is still stock for now. want to lower so i know ill need new spindles. i want disc for a 5x100 , and i know i can these. i assume i can use stock ghia calipers scine the disc ill be using are for ghias also. so what else am i missing? and any tips where to get great deals?
Neil Robinson
REMEMBER ... think VW not PORSCHE
Old May 4th 2004, 17:36
You cant get a drop spindle set already drilled for 5x100 for get the set blank and get your studs (press in) from a local parts house and have a machine shop drill them and press in the studs. If the set dose not have them, I would go with new bearings lines and ball joints/tie rod ends. Don't forget a good alignment.
