T4 Headstuds & copper gaskets
I'm (eventually) gonna be running 8.0:1CR & Turbo on 1971cc T4
Anyone got any suggestions regarding uprated headstuds/Std new studs/reuse old studs? Also where to buy them from? VAG (UK) list std new studs @ just over £150GBP for all 16. (but they've only got 4 of one length in stock) Do I really need copper headgaskets. Aluminium isn't a great deal harder than copper & cylinder heads are already made of it (!) Thanks Martin
+44 (0)7812 167547 martinandsonjaATf2sDOTcom |
I don't know about sources of studs in the UK but most builders are not running gaskets at all. Ensure your cylinder/head mating surfaces are true and cut the ridge like Oliver showed in a previous post and you should be fine.
ken |
I'm using stockers on my 2165T. Cro-moly doesn't flex enough. My builder runs stockers on his 1776T buggy with 25 PSI. Not a problem yet. Sometimes you're just paying for hype. 8.0:1 might be a little high for a turbo(on a T1 anyway). You'll want to be around 7 or 7.5:1. 8.0:1, you risk higher head temps. So the only reason you might want to use a copper gasket is to lower your compression.
Julian '74 Super "If you are under control you're going too slow" - Parnelli Jones Last edited by lightning bug; September 26th 2002 at 19:23. |
I use original studs for my engines, only de-stretched and plated through a shop here. On normal engines I use them as they are, USED! Maybe Limbach studs would help. They are done for the aircooled waterboxer conversions and for the Type 1 airplane engines. These are awesome. 200 Euros a set!
Click here to mail me! |
