Old May 30th 2004, 22:14
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Bobtail, help.....
Ok, so I now have a new T4 case with 102mm nickie cylinders and J&E pistons. I am thinking about taking the plunge into 911 heads and now wonder which ones to use. I am thinking turbo'd so should I look at 993 turbo heads? As far as the Polo sprockets, is this something I could get one of you in the UK to source as we do not get the Polo. We would still need to clear up the cam building idea of pinning? Would it not be better to section the cam and TIG the pieces back and re-heatreat the cam? Any new pictures of the engine changes?
Randy
Old May 31st 2004, 08:41
BOBTAIL BOBTAIL is offline
Randy
Hi Randy 993 heads sound good to me
I will get all the info regarding cams and drive and post it
Did you notice the second oil pump on the cam?
www.centralvwaudi.com/protoruss.htm most of the latest pics are here I will add the last ones I have during today.
I also have some parts you might like
Ps 0151 357 4079 not sure on the int code for it I think its 44
