Old May 31st 2004, 20:09
yetibone's Avatar
yetibone yetibone is offline
1303 Progress
The relief of getting Sue's '98 Passat back together Saturday was quite motivating, I must say. I dragged the 1303 out of the woods and into the garage last Saturday, for something to do, and since I had to pass up seeing Rush again this weekend, I decided to start tearing it down.
I got the interior out completely. The only thing I saved was the seats, steering wheel and column, and the wiring harness and switches. Found out the car had been hit on the right rear, behind the door. Dents were pulled with a spot-weld slide hammer, and the bodywork was done very nicely, not a "cave and pave" job. The body needs front and rear aprons, rear window lower corners, and patch panels under the half-moon vents.
I got the body off the pan, and scraped up all the old tar boards, and found only one 1" rust hole in the inside corner of the battery box. Should be an easy fix . Removed all the old heater cables, and controls, handbrake, shifter and shift rod, pedal assembly, and master cylinder.
TO DO:
Fix the hole.
Get a pre-'73 moustache bar to mount the drivetrain
Make the 901 fit
Make the 914 shifter fit
Make it shift gears
build a cross-member and front trans mount (aluminum or steel; your thoughts?..)
Build a Kafer Cup Brace
Install 944 brakes and suspension in rear
Aquire, and install later 1303 front arms, Kerscher joints, and 944 brakes
Paint the pan
TO DECIDE:
What kind of struts? Make my own, or take the easy route with some MaxxStruts?
Use my steel 944 trailing arms, or try to score some aluminum ones? 3" wider rear fenders are in the plans, so late 951, 952, and 968 arms should work.
Once thats done, then I'll start on the body :help:
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 31st 2004, 20:51
Enough talking about it, get to work.
Old May 31st 2004, 20:56
That reminds me... I have things to do in my garage...
Old May 31st 2004, 21:06
yetibone's Avatar
He he, "Man up and wrench" you might say...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 31st 2004, 21:14
I like that...^ It has a nice ring to it...
Old June 7th 2004, 19:59
yetibone's Avatar
Heard from Len, the heads should be ready in 2 weeks.
heard from Charles the lifters will be ready sometime soon. (?)
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old June 27th 2004, 20:00
yetibone's Avatar
Got my heads back from Len Hoffman last week. 1.7 "Q" heads, 42x36 valves, 57.5cc chambers, P&P on the exhausts, and polish only on the intakes. Tapered guides, radiused stems...
BOIOIOIOING
Len does some fine work. These look like new heads! If you want Type IV heads done right, and don't mind waiting, I recomend his services implicitly.
Gonna need .090 spacers to get a .040 deck, so they are on the way too.
I'll figure out the rocker geometry and pushrod length next, but first I need the lifters from LNE...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old June 28th 2004, 01:05
COOL.
? I thought that polished intakes were bad because they are more prone to causing fuel to drop out of suspension from the lack of turbulance.??
Old July 2nd 2004, 20:14
yetibone's Avatar
You don't want turbulence in front of the intake valve. The intake charge must be smooth, straight, and kinda shaped like a teardrop as it reaches the valve.
After that charge enters the combustion chamber, THEN turbulence is an advantage. If you can get the charge to roll into a vortex after it passes the intake valve, it will draw a larger plug into the combustion chamber, thus having a ram-charge effect.
Think about a roll of toilet paper, and how much space it occupies when it's on the roll. Now think about that toilet paper when it's unrolled, like all 500 sheets. It would cover the floor of your bathroom. A roll of hockey tickets is dense, a wad of hockey tickets isn't. (what an analogy ) If you can get the plug smoothly thru the intake port, around the intake valve, and make it swirl as it gets drawn into the chamber, a more dense air-thus-fuel mixture can be burned during each cycle.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old September 19th 2004, 19:33
yetibone's Avatar
Well, Toccoa must'ive done something to me, that, and my Ahnendorp header arrived while we were in GA. I spent 12 hours this weekend on my Bug doing all matter of stuff.
I spent most of Saturday doing math 'cause it was raining. After talking wid Len, I found out that I need to run ZERO deck height on my engine. He gave me a .040" step-cut in the chambers to keep the pistons safe, so I had to re-fig the rocker geometry, and pushrod length. I have to use .060 rocker pedistal spacers to get the valve, and adjuster parallel at .250" lift, and use 274mm pushrods to get a good range of adjustment. Ordered snap-ring type wrist pin retainers ('cause I hate spiral-locks ), the pushrods, rocker pedistal shims, and some other stuff.
The weather today was nice here for a change so I rolled the pan outside and spent most of this afternoon fitting the 901 to the chassis. Got the holes drilled in the bellhousing for mounts, and attached the mustache bar, got my aluminum crossmember mounted to the tranny, and measured for, and drew up a plan for chassis mounts for the front of the drivetrain. Cut the access panels for the shift-rod joints and bushings.
Finished up the rear suspension basics. Arms are on, shock towers modified for 951 springplates, springplates are on, parking brakes done, cables attached on both ends. Gotta take the right side back apart though, as it seem as if I've indexed that torsion bar lighter than the other when I jump up and down on the frame horns :doh:
I'm shootin' for firing it up by Dec.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old September 20th 2004, 00:31
Man you work fast, I haven't even seem my car in 3 weeks. It is still burried under all the hurricane stuff. You are making me look lazy, and I just can't have that. :agree:
