Old June 4th 2004, 06:24
77bus 77bus is offline
relay problem
I am fitting a fi type4 engine from a 412 into my baywindow. I have been having problems finding the relay board and relays to power the ecu and fuel pump.
Does anyone have these parts or know where I could get them? I also need the part no for the ecu relay. Are there other relays that will work? What values would I need to look for?
Thanks andrew.........
