Old June 9th 2004, 14:32
Rob's Avatar
Rob Rob is offline
Mounting a Rabbit fuel pump
Is there a special bracket to mount a Rabbit fuel pump ?
Also, what are you guys using for fuel lines ? I assume I need high-pressure rubber lines ? (when I am not using copper or steel).
Is there a special connector for the pump, there is a threaded end, and I am wondering if I need an adapter.
Thanks!
Rob.
