Go Back   GermanLook Forums > Vendor announcements > Group buys
Old June 28th 2004, 21:37
944 e-brake adapters...
Would anybody be interested in buying/making some e-brake adapters for the 944 swap? I am almost finished with mine and I can take some measurements if anybody is interested.
Something like this.
Old June 28th 2004, 23:32
DORIGTT's Avatar
DORIGTT DORIGTT is offline
I'm interested in acquiring a set for my Ghia
Old June 29th 2004, 00:03
Cool, thats 1 so far. I think being able to buy them help out a lot of people that don't have access to a welder. :agree:
Old June 29th 2004, 09:55
LOAF's Avatar
LOAF LOAF is offline
BG
Not having taken the body off yet, I have not idea what is in store for me..
How does this work.. These get welded to the Beetle torsion housing?
Do you keep the 944 Cables that come off the calipers..
Can this be used with the Alum. Arms.
How much..
Hopefully not to expensive, Just bought the 14mm/12mm from another member, some new tires for my wifes truck and some new tires for my car..
Man when it rains, it pours..
Either way if it will make it easier, I am in..
Can you post a pic showing where they get mounted..
ALex
Lost and Confused.
also a
Old June 29th 2004, 20:04
kiwivw kiwivw is offline
I would be interested in a set, how much?
Cheers
Craig.
Old June 29th 2004, 21:33
[QUOTE=LOAF]BG
How much..
Can you post a pic showing where they get mounted.. [QUOTE]
They are used to adapt the beetle e-brake cables to the 944 e-brake hardware. The 944 uses a pin with special cir-clip to secure the cable to the shoe spreaded and the beetle uses a swan-neck hook to retain the cable.
You can use stock cables with the (elbow) ends filed down a bit with the aluminum arms.
File Type: jpg shoe spreader assembled in trailing arm.jpg (71.6 KB, 68 views)
Old June 29th 2004, 21:42
I have contacted a shop already and am waiting for a reply. I don't have the time or the resources to make them myself.
Old June 30th 2004, 10:55
LOAF's Avatar
BG
Sounds good..
So to recap..
You keep the stock beetle cables going to the 944 E-brakes.. You use this nifty adapter in place and some washer to add some tension by where it enters the Alumn Arms..
Is that correct..
Plus I am interested.. looks cool.. I haven't taken the rotors off the rear assembly yet.. so that is why it did not make sense..
I need to pickup a rear brake caliper rebuild kit, rotors and pads.. So I was holding off..
ALex
also a
Old June 30th 2004, 22:11
Originally Posted by LOAF
BG
Sounds good..
So to recap..
ALex
You have to file the end of the cable where it goes into the trailing arm from 14mm diameter to 12mm diameter for the aluminum trailing arm. If you are using steel arms you shouldn't have to modify the cables at all. I added the washers to take up some slack in the cables since I file down the ends too much. I also have old emergency brake shoes and wanted some adjustability in the system for when I get new shoes and rear rotors.
Old July 13th 2004, 00:53
55rag 55rag is offline
I'd be interested in a set if it's not to late.
Do you have prices yet?
Old July 13th 2004, 01:50
Haven't heard back from the machine shop yet. I'll try again maybe he never got the e-mail. I have all the dimensions so I can send anybody interested in making them the plans.
Old July 13th 2004, 20:53
I would love to get the dimensions if you don't mind.
Old July 14th 2004, 00:09
If you have a fax line that would be great since I could send the dimensions full size. What I did was place the part in the copier at work and made a few copies. I then wrote down the important dimensions. Let me know how you want it sent.
Old July 14th 2004, 10:52
You can fax it to 714-688-5407. I appreciate it.
Old July 14th 2004, 13:27
LOAF's Avatar
BG,
If Machine shop deal doesn't fall thru would you be willing to post a scanned full size pic.. For some of us with no access to a fax
also a
