Old June 29th 2004, 13:06
bfenenga bfenenga is offline
Front 1 side suspension sag
Hi,
I've built a Porsche 550 Spyder and have a bit of a sag on the drivers front side of about 3/4". Could it be that I need to replace the torsion springs or the adjuster nuts are AFU?
Thanks.
Bert Fenenga
Old June 29th 2004, 20:41
Try removing the shocks to see if the problem goes away. At least rule them out as the cause of the problem.
Old June 30th 2004, 11:54
Good suggestion, I'll do that this weekend.
Thanks.
Bert Fenenga
Old July 2nd 2004, 06:35
Bruce2 Bruce2 is offline
The first thing you have to do is make sure you really have a problem. If you are measuring from the fender to the ground, that's probably your mistake. The body won't be as good as you think. Measure from the front beam to the ground.
If you still have a height variance, check the rear. If the front left is low, you will find the right rear is high. Drop the right rear and the left front will rise.
Old July 2nd 2004, 14:01
Good point. My next question then would be how do I drop the right rear? Dropping the whole front is 'easy' with the adjusters but how is the rear adjusted and also how just one side?
Bert Fenenga
