Old June 30th 2004, 01:16
Stock Alternator? Make upgrades? Porsche?
I'm looking to get a 72 SB currently stock. Plans for a motor of some kind. Rotory mabey.. but if I got a Type 4 with upright cooling I'm curious about the factory alternator. I've got a sub from my old car I'd want in my SB a 12" Pioneer TS-W304C powered by a USX-2100 that's got a 35A blade fuse. (300 Watt) can the elecrical system handle something like that? I could sell it and get something smaller. Or do they make bigger alts?
Old June 30th 2004, 04:13
you can get a bosch alt. in 75 and 95 amp. The stock al82n is 55amp.
Old June 30th 2004, 19:38
If end up running a Type 1 engine or a Type IV with upright conversion stay away from generators, they absolutely suck for powering a system.
Old July 1st 2004, 00:24
Did the SB's even have generators? Are they 6 volt or 12?
Old July 1st 2004, 00:51
71 and 72 Supers had Gen. they went to an alt. with external regulator in 73 then an alt. with internal regulator in 74.
Old July 1st 2004, 00:53
That I didn't know..
Old July 6th 2004, 11:57
ShApE's Avatar
ShApE ShApE is offline
ok i got a question, i have a 71 super beetle with a t1 and i took out the generator and put in an alternator, everything is workin fine and dandy but do i still need that thing behind the drivers seat, i forget what to call it, like a power converter or regulator. but now that i got the alternator do i still need it?
-= 71 super =-
-= 86 944 turbo =-
-= 84 911 carrera (dad's) =-
-= 99 ford explorer =-
-= 2005 Cayenne S =-
Old July 6th 2004, 11:59
Do you have an internaly or externaly regulated Alt.?
Old July 8th 2004, 15:26
ShApE's Avatar
im pretty sure it's internal.
-= 71 super =-
-= 86 944 turbo =-
Old July 8th 2004, 19:05
On my '72 1302 I converted to a internally regulated alternator long ago, and tossed the stock voltage regulator...excess weight.
Nick
Old July 8th 2004, 19:50
What alts can you use? What's the power rating? Mods to make them work?
Old July 9th 2004, 07:59
Stock Type 1 style alternators come in 55 amp, 75 amp and 95 amp. They will work with any type 1 shroud or a DTM shroud for type 1 or type 4.
Porsche alternators must be used with a 911 style shroud. I don't know all the amperage ratings of the Porsche alternators.
Old August 17th 2004, 08:47
Chris Percival's Avatar
I have asked this question on the typ4rum too, but can I use my T1 regulator (my T1 alternator is 50A) with a 35A alternator on a porsche fan unit? Will the alternator still charge correctly? Or will I have to get another regulator suitable for the 35A output? I would love to use the original regulator as that would be neat, and would save me having to buy another...
Chris
Old August 17th 2004, 14:08
good way to fry the alt. i ordered a '73 911 regulator. was about $45 US. i think i got it from Vertex Auto out of Miami. good prices there.
Old August 17th 2004, 14:50
Why would it do that?
