Old July 31st 2004, 09:20
kra710's Avatar
kra710 kra710 is offline
How much did you spend on the front (beam)
Franklins Baywindow Beams Are pretty Pricy with the modified 944 4 piston brakes. I am considering them since Next year or even as soon as this winter I will be Rebuilding the type 4 engine in my bus for more power. Typically how much would you guys say you spend on your front suspensions, On one hand I think that having the stopping power of some porsche brakes would be awesome, but I am also thinking that this can be overkill and all i need is a narrowed adjustable beam? any thoughts
GermanlookT2
Old July 31st 2004, 18:07
Panelfantastic's Avatar
Mine is a split so its a little cheaper...but here's my thoughts,
I narrowed my own beam, it was a ton of work especially since I did not know what I was doing... I would not do it again, ever. I know they are expensive but it is much better left to someone who has a jig made and has done several so they know how to avoid mistakes. The beam comes out looking better and your peace of mind stays up.
I bought the 944 brake conversion setup from Oldspeed. Nothing revolutionary in the kit but all the parts they sent were nice. If you were best friends with a machinist and knew exactly how to set everything up, you could build your own caliper bracket and have spindles/races made to allow everything to bolt-on. Franklin has hours and hours in mock-up and machining and that is part of what you pay for.
Bottom line, if you can save up and buy his or someone else's kit, do it. If I started from scratch all over again (heaven forbid), that is exactly what I'd do. I get a great deal of satisfaction out of building my own stuff but some parts really aren't worth getting into.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old August 1st 2004, 12:10
Ditto! I had my beam narrowed by a local welding shop. It took forever and they ended up warping it. If time is not an issue, and I mean REALLY not an issue, and you like to tinker, go for it. Otherwise work a little bit more and buy it done, then if there are any problems you have someone to ask and someone responsible for it.
