Old August 5th 2004, 12:18
volksdragon's Avatar
warped rear drum?
anyone ever seen a rear drum warp so bad that the wheel wobbles?
i thought it was the stub axle was bent and had it replaced but the wheel still wobbles.
they are brand new rims so i know the rim is straight.
any ideas of stuff to look for that might cause this.
thanks
Old August 5th 2004, 15:52
Hrvoje-ZD's Avatar
Hrvoje-ZD Hrvoje-ZD is offline
I had the same problem on my 1971 1302L few years ago.The wheel bearing was completely worn.I replace it and now it is O.K.
My english is bad but I hope that you will understand me!!
Old August 5th 2004, 16:20
when you where driving did it look like the wheel was wobbling?
when i jack up the car there is no wobble like when a bearing is bad.
it feels very solid
Old August 5th 2004, 16:41
jack it up, put your hands at 12:00 and 6:00 and push/pull in opposite directions. if it has play, your bearings are bad. also make sure the drum is seating properly.
Old August 5th 2004, 17:05
thats what i meant with the car off the ground there is no play in any direction.
when i find my 36mm socket i'll pull off the hub and have a look to see if it's on properly or if it's warped.
thanks guys :agree:
Old August 12th 2004, 17:17
Hrvoje-ZD's Avatar
Well I didn`t notice any vobbling by my self.A friend drove behined me and told me about vobbling.First I suspected on tire than wheel,drum and after that I realised that the problem was in the bearing.
Old August 12th 2004, 18:34
i found my 36mm so i'll pull the rear hub this weekend to check the bearings and check the drum
thanks
guys
