Old August 8th 2004, 00:34
NCbug NCbug is offline
94 civic coil on a sb
I have a 1972 superbeetle and i want to put 17 inch rims on my bug but i the coil is to wide so , is it true i can put rear coils on my bug and it will give me enough clearance to fit my 7 inch wide rims or can i fit the front coil from a civic on it too. thanx alot
Old August 8th 2004, 01:26
volksdragon's Avatar
as far as i know you use the rear coil from a crx or civic. also you need the rubber spring seat.
if you go to vdubcustoms.com i beleive he has a kit for mounting these springs. also you can go to toplineparts.com and get they're maXX struts.
