Old August 11th 2004, 17:24
rip's Avatar
rip rip is offline
wheel help
So I was the guy talking about rims other than the empi's that every one uses, and getting some $$$ porsche rims. Any ways I found some wheels that I like and should be able to find them used at a good price. They are 5 spokes that look sort of like twisties, I try and post some pics. But, the problem seems to be that the offset is large, probably to big so I wanted to see if any one here has dealt with rims this size.
2003 Mazda 6
17 x 7
5x114.3 (bolt pattern)
lugs are 21mm with a 12x1.5 thread (if it matters)
60 mm offset
And there is the issuse the offset +60mm.
I know that a lot of people run the boxer rims with the +55 offset, but any one run anything bigger? How could I make this work on a 1970 pan? Ball joints / IRS.
thanks for anyhelp.
Rip
Old August 11th 2004, 17:36
rip's Avatar
rip rip is offline
http://i1.ebayimg.com/01/i/02/39/b3/a7_1.JPG
Old August 11th 2004, 18:51
if needed you can just use spacers to make up the difference. would only have to be 5-10mm.
Old August 12th 2004, 02:17
rip's Avatar
rip rip is offline
Zen thanks for the reply
And I did some re reading of the article and some old posts, and I wanted to make sure I got some things right. With a stock suspension a 17x7 +35 offset will fit well under the stock fenders right?
so In actuallity I only need to make up for that difference in back spacing. So I would need to use a 25mm ( 60-35=25 ) spacer to make it fit. Aprox ~ 1 inch.
So If I wanted to I could simply buy a 1 inch Bolt adaptor and the rims would work. Right?
This is what I was thinking. I need to narrow the front beam, given. And I'll be using the CB performance disc brake, Don't really have the resources to go 944. And will need about a 25 mm spacer/adaptor.
but what problems will I run into with the rear? I know the issue with "That Bolt" and the rear bump mount. But will I need to space out the rear at all? Also planned on the rear discs but was hoping to stick with drums for a while.
this all seem about right?
how far narrowed on the beam should I go? (I like the new CB beams only 2")
What do I have to do to the rear?
Also how would all of this effect the steering? Would I still have a close to stock steering circle?
thanks Again
Rip
