Old August 16th 2004, 14:38
MrMoo MrMoo is offline
944 upgrades - some help plz
ive got early 944 setup all round at the mo
front end using drum spindles with adapter
the rear end early 944 arms
i wish to upgrade to brembo 944 turbo calipers
can i just change the calipers over???
can i use the 944 non turbo disc's???
sorry im sure its been asked b4 but i dont have a clue
hopefully its gonna be a resonably easy swap over
cheers Mickie
Old August 16th 2004, 16:04
I'm pretty sure that the turbo rotors are thicker than the N/A rotors were so you would probably need a set of those to go with the calipers. I think they are thick by 2mm or 3mm but I'm not sure off the top of my head. When you said that you had the early arm in the rear did you mean that you have steel arms or the early aluminum trailing arms. Wait that doesn't matter since all of the rear brakes use the the same bolt spacing as the turbo calipers I think.
The rear should just be rotors, calipers, and I think a few washers to get proper alignment of the caliper on the rotor.
You will need another caliper adapter since the bolt spacing is different on the front turbo caliper compared to the N/A caliper.
Try a using the search function, the information has been covered before and the answers are there somewhere.
