Old August 31st 2004, 13:30
8v fury 8v fury is offline
1968 bug that needs a 5 speed.
I own a 1968 bug with irs front and swing axles in back. I dont have a irs rear on my bug. Would like to do the 5 speed transmission conversion, but don't know what I can do and use to make it work. Plus I can't afford another pan (irs) due to space where I am at and family. If anyone has any information or point me in the right direction that would be great. The main reason for the 5 speed is I drive the freeway alot and some long distance driving with the kids.
Old August 31st 2004, 16:04
You can use a freeway flyer or put a 3.88 R/P with a 0.82 4th. in your trans.
Old September 1st 2004, 05:45
Bruce2 Bruce2 is offline
If you can't afford an IRS pan, you can't afford a 5 speed.
The 2 most common 5 speeds to use are the Berg 5 and the Porsche 901 5 speed. By the time you rebuild a Porsche trans ($$$$) and install it with all the extensive fabrication work, you will be into it for at least $2-3K.
The Berg 5 can be made with swing axle to bolt into your car, but the cost of the parts alone are near $2k, then you have to get it built. Any upgrades you need will easily push it well over $3k.
Old September 8th 2004, 14:31
Well, my friend works at a porsche repair shop and will give me one out of a wreck car he has in back. So, right now just need to know what I can do to make it work.
Old September 9th 2004, 05:37
You need to spend some time in this forum reading the past topics. The conversion to a 901 5 speed has been covered in depth.
Old September 10th 2004, 17:08
kdanie kdanie is offline
"Extensive fabrication" is not required, you DO need to convert to IRS but that is possible too and acually more work than the 5 speed.
ken
Old September 11th 2004, 15:52
Compared to installing a swing axle Berg 5, installing a 901 5 speed requires "extensive fabrication".
Old September 12th 2004, 23:17
Got some good news, my friend just located at 69 irs pan that is in really great shape, no body. So it looks like someone is watching out for me. Don't know when I will start, due to work and injury. But when I do, I invite you people up when I do this. I will keep you updated and let you know when it will be started.
Old September 13th 2004, 08:58
It will be a much smoother project with an IRS pan and if you get a good 901 from your friend. Remember that the 901 like Swepco gearbox oil.
Old September 19th 2004, 01:23
KaferChris KaferChris is offline
Make sure the pan has a title and that you get it...definitely look into state law concerning body swaps.
Old October 8th 2004, 16:42
Well, there is paperwork for the pan, so that is good and yes I can do it.
