Old September 19th 2004, 18:04
1303vw73 1303vw73 is offline
Questions about 1303vw73s ride
Click here for more information on this ride.
Old September 19th 2004, 23:23
Vincent's Avatar
Vincent Vincent is offline
looks nice I have not been a big fan of the chrome twists but they look good in contrast to the metalic blue of your 1303. Looks like you might want to bring the ride hight down just a bit. the back looks pretty high as does the front. It will help in the handeling too lowers the CG for the car. Good luck with the project at least yours is on the road.
I did this in photoshop to show you how low i was thinking would look good.
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
Old September 21st 2004, 15:07
thanks Vincent for the reply. I would eventually like to lower the rear end, but I am still unsure of what my options are and how the process is done. I don't want the rear wheels to have and excessive negative camber like i see on other cars that are lowered in the rear, but a loewr stance would be nice. The front is lowered 2.5 inches with Maxx struts. I was curious to see your picture, but the link did not work.
thanks
Kyle
Old September 21st 2004, 16:05
nice ride. you can get the back down without excessive camber. you mostly will see that on the swing axle bugs. yours being IRS is a little more forgiving.
Old September 21st 2004, 17:50
if you only lower it one spline in the rear you will not have excessive neg camber. You will have a little neg camber (1 to 3 degrees), but it will improve your handling.
Nice wheels
Old September 21st 2004, 23:52
When you say lower the car one spline, do you mean just move the spring plate one outer spline, or move the inner end of the torsion bar one spline also, like the Bently manual describes? How much will one spline lower the rear end? Will the negative camber have any major effect on the wear of the tires? Thanks guys for all of the information.
Kyle
Old September 23rd 2004, 16:36
Vincent's Avatar
Sorry about the bad link here is the picture
here is a link to the before and after
before and after
Vincent W. Strader
plans
Old September 23rd 2004, 23:08
That looks much better. Thanks for the pictures.
Kyle
Old September 24th 2004, 01:57
Vincent's Avatar
Your welcome I like the way it looks lowered better.
Vincent W. Strader
plans
Old October 16th 2004, 02:15
Superman
Originally Posted by Vincent
Great looking car :agree:
