Old October 6th 2002, 12:35
Alex's Avatar
Alex Alex is offline
Post How to create your profile...
On the main page on the left side you will find a Submissions box. In it there is a "Members Profile" link.
Once you select that it will ask you for forum member ID and password. Only members of the forum are allowed to submit their ride.
Once you authenticated you are able to create your profile with details of your car. After that you are able to upload 4 pictures. Make sure that the pictures are at least 640x480 in size for the best quality. Pictures that are smaller will be cropped to that size decreasing the quality of the picture.
A thread for your ride will be automatically created in this forum.
If you have any questions about it please ask them in this thread.
GermanLook Team
Old January 10th 2004, 13:16
Xzenor's Avatar
Xzenor Xzenor is offline
its not working!!!!
Its not working for me!!!
Xzenor
Old January 10th 2004, 13:48
Alex's Avatar
I think there is a problem with code using the database of the old forum to log in. I have to talk to Sandeep about this.
This might take a while.
Old January 10th 2004, 18:27
Xzenor's Avatar
Avatar?
Cant edit avatar either!!
Xzenor
Old January 10th 2004, 22:08
Alex's Avatar
The avatar needs to have a certain pixel size. What is the error message you are seeing?
Old January 11th 2004, 11:15
I'm looking at the code today ...
Old January 11th 2004, 17:20
Xzenor's Avatar
No fault code....
I cant change the little dot on the "do not use avatar" screen. It doesnt do anything when I click on it.
Xzenor
Old January 11th 2004, 17:26
Alex's Avatar
Do you actually select the "Use custom avatar" dot?
If you use that the do not use avatar dot will go away. Works for me.
Old January 11th 2004, 17:48
Xzenor's Avatar
Yes....
I dont Understand why it doesnt work for me. Ever since we got this new forum it hasnt worked for me. I even tried making a new user ID and password....same problem. I cant even get into "Member Profile" with my new one. I was able to with my old one......but not no more.
Xzenor
Old January 11th 2004, 22:01
Alex's Avatar
The member profile on the main page does not work. The new forum uses different authentication encryption.
We still have to figure this out. Does the avatar now work?
Just be patient....no one can update their members ride at the moment.
We are working on it.
Old January 12th 2004, 13:07
This section of the site is available again ... sorry for the delay. The colors throughout the whole site will be changed to match the forums so don't be alarmed when you look at a page and the colors are not correct.
Hope to have this fixed for Wednesday morning.
Old January 20th 2004, 15:44
Richie's Avatar
Richie Richie is offline
Hello,
Well, I thought it was time to put an avatar in my profile, but it doesn't work for me!
I don't even have a "use custom avatar" button! It sounds I've the same "problem" Xzenor mentioned. Maybe it's just me having my fingers in a cyberknot !
Cheers,
Richard
Old January 20th 2004, 16:01
Alex's Avatar
Click on "User CP" upper left corner. Go to "Edit Avatar" on the left menu bar.
Select "Use custom avatar" and upload you avatar from a web site or local hard drive.
Also in the "Edit Options" on the left menu bar of your User CP make sure that you have "Show Avatar" enabled.
Old January 20th 2004, 17:56
Racelook's Avatar
Racelook Racelook is offline
Hi ALex
I also wanted to chance my avater..
I can find th eusercp and the editavater button but where is the use custom avater button???
I don't see im.
Wiebrand
B-Extreme B-Tuning.....
Old January 20th 2004, 18:13
volksdragon's Avatar
i'm having the same avatar issue.
here's what i get
