Old September 26th 2004, 12:51
VRSICK VRSICK is offline
heavier engines, stiffer rear suspension?
I am planning in an 8v watercooled engine, and plan to drive it hard. Anyone have any suggestions as to where to look for a decent susoension setup for such a combo? I have koni reds now, but i'm not sure how it will hold up. I guess i'll find out once the engine and tranny are back in the car, and I put the brakes on and the wheels and see how it goes...
thanx in advance :agree:
Making my 70 Beetle into a GL
Old September 26th 2004, 13:13
you may want to run larger torsion bars in the rear
Old September 26th 2004, 23:26
944 rear torsion bars start at 23.5 mm and get larger from there. Your stock ones are 22mm for reference.
Old September 27th 2004, 11:16
Move the tranny forward and as suggested go for heavier bars.
Old September 27th 2004, 11:39
Vincent's Avatar
Vincent Vincent is offline
you could install real coil over shocks that have diffrent spring sizes. they are a bit pricey but give you more tuneablity
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
