Old October 4th 2004, 07:27
bugmeister bugmeister is offline
Is ball joint really better handling
I am tossing up suspension and braking ideas and was wondering whether ball joint front suspension really provides a handling improvement over king and link pin. If the difference is noticable then I'm more than willing to perform a framehead swap in an effort for improved handling.
Old October 4th 2004, 21:23
I'm no expert, but I'm going to say its not worth it. They are both trailing arm, the shortcoming of the design. The balls just don't wear as much I believe. I suspect you may even have an advantage with link pin in that you can increase camber over the ball joint's eccentric abilities.
My $0.02
Old October 27th 2004, 13:59
rip's Avatar
rip rip is offline
actually both will perform just as well on the street. Ball may be a little better in the bumps.
Link pins do however require more maintance, greasing and all.
Not really worth it.
Old October 27th 2004, 14:01
rip's Avatar
rip rip is offline
may be think about a pan swap. IRS and ball joints in one. depends on what you want to do.
