Questions about Jims ride
Camber Adjustment?
Hello Jim?
Jim, what did you do to get more negative camber? I have put the 944 brakes on my 1978 cabriolet, but I have alot of possitive camber. I need some help, what ever information you have would be a big help. Thanks, TOW74 |
Dear Friend
There are several ways to face this problem.. First is came from Topline parts called Camber kit ++ which allows you to play +1 -1 positive or negative and installed in both sides of your control arms. Second came from H&R and it's Triple C Camber Adjustment Bolts which allows you play on the upper of the strut 0-3 degrees, positive or negative. As we speak write now I have the same problem 1/2 inch on each side and I have order both H&R and Camber kit to correct the problem, so when I receive the parts I will inform you if I have succed. Try a quick search on Germanlook for camber kit this will help you. hope that helps ![]() |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
