Old October 31st 2004, 23:28
73notch's Avatar
73notch 73notch is offline
High perf and stock type 4 engine parts 2270
:-( my entire t4 engine lot is up for sale. hopefully ill be able to do it later on.
help me out.
heres what i have
-78.4mm DPR stroker crank with type 1 journals(stock rod journals, 10 on mains)-400
-96mm piston and cylinders(already machined by rimco to proper specs) and hasting rings-350
-H-Beam Rods, type 1 5.395"-300
-Webcam 163/86b broke in on dyno only.-75
-HEADS
-1.7l heads, recently rebuilt-100
-1.8 heads-75
-2.0 heads oval ports, non porsche-75
-New Johnson lifters
-2L crank and rods-100
-1.8L crank and rodsx2-50 each
-2 cases in good condition, 1 is polished on top, the other isnt. ?
- 1.7 p+c set, barely used, couple broken fins-40
-new 210mm clutch-10
-bus 210mm flywheel-40
-210mm new pressure plate-30
-porsche 914 flywheel-50
-fuel injection system off of 1.8l engine-100
-used 1.8l p+c set-30
-3 94mm cylinders-30
-stock aluminum pushrods-15
-valve covers-10
-windage tray-10
-2 fan shrouds w/ alternators-40 each
-CB carb manifolds-35
-rebuilt 42 DCNF carbs-250
-DCNF t1 manifolds-30
-DCNF t4 Shortie manifolds(very short, good if you are putting in a type 3)-50
-Both of Jakes Bug Me videos, How to rebuild your T4(VHS)-20, and DTM install.(DVD)-20
Email me with offers.
Shipping not included in price
After a week, they are going on ebay
If you need something not on the list, ask me, I might have it.
pics are http://www.cardomain.com/memberpage/426700/2
www.subynotch.com
Old November 4th 2004, 18:44
Bad bug's Avatar
Bad bug Bad bug is offline
2.0 crank and rods
Do you still have the 2.0 crank and rods and has it being cut already or is it a virgin crank.
Old November 11th 2004, 22:12
jrinlv jrinlv is offline
hey I sent you a PM did you get it? I want to know what you have still? thanks JR
