Old November 2nd 2004, 08:56
Bad bug's Avatar
Bad bug Bad bug is offline
Kafer cup brace
Hi Guy's,
Where can i find a 5 bar kafer cup brace. What's the price like.
Old November 2nd 2004, 13:45
danielzink's Avatar
I've been eyeing THIS brace for a couple of days now.
Anyone have any opinions ?
Dan
65 notch 2300cc type4
www.danielzink.com
Old November 3rd 2004, 02:40
SuperRSi's Avatar
SuperRSi SuperRSi is offline
My personal opinion is that the Cup type braces from each shock tower down to the motor mount would add strength to resist side to side motion of the mount and acceleration motion. And this illustrated brace would strengthen the mount in drag race, straight line acceleration of engine masses. And either would be much much better than none. Hard to tell. Then the question becomes when do you stop triangulating the chassis. At some point you just might as well weld in a full cage with suspension pick-up points.
Randy
Old November 10th 2004, 15:42
rip's Avatar
rip rip is offline
Dan
will that clear the trans mount? should just curious if the bolt tabs that fit to the frame horns would go between the mount and frame horns or after them? as it may space the trans out.
rip
