Old November 18th 2004, 19:49
Brake dust
The steering was vibrating from 90-115km/h, so I thought it might be the wheel out of balance, went to balance it, still did not solve the problem, so it might be the bearings, took the rotors off, bearings still in good condition, then I noticed the brake dust accumulated in the drilled holes on the in side rotors. took a 4mm drill bit and cleared all the dust and went to test the ride, all was ok! Anyone had this problem before?
T4 2666 1303s
