Old October 14th 2002, 15:41
MattKab's Avatar
MattKab MattKab is offline
Rear wheel drive speedo
Any suggestions on how a speedo cable could be driven by the rear axle? Perhaps 1:1 gearing from the output flange.
I'm running 215/40ZR17 upfront (596mm) and the correct ~636mm diameter at the rear using 225/45ZR17.
Any ideas?
Matt
Old October 15th 2002, 01:57
Andy White's Avatar
Hi Matt,
You could always just get the speedo recalibrated for the new O.D.
Regards,
Andy
'55 oval GL
rears
230BHP TIV fuel injected.
IRS+Berg 5 speed box.
Build in progress.
Old October 15th 2002, 09:02
The new VDO speedos use an impulse from a sender, you could stick some magnets on your cv to produce an impulse for the speedo.
Steve C
Old October 15th 2002, 13:39
MattKab's Avatar
Smile
Can the speedo be recalibrated?
I would like to use my stock speedo, as anything else looks odd in the 1303 'hole.
I'll check the VDO website.
Anymore ideas?
Old October 15th 2002, 18:16
kdanie kdanie is offline
Most speedometer shops can set up a small gearbox to change the ratio to correct for different tire sizes. Not a big deal, it just fits between the speedo and the cable.
ken
