Old October 14th 2002, 17:31
hot66's Avatar
hot66 hot66 is offline
tyre sizes again - 40 or 50 profile?
just bought 4 genuine porsche cup2's, 7x17 et55
what tyre sizes do most people run?
I was thinking of 205/40's on all 4, but it seems Porsches run 205/50's as standard on this size of rim.
Has anybody got a picture of 40 series & a 50 series tyre to compare?
project in progress
Old October 14th 2002, 17:46
205/40/17
Tire Diameter: 23.5"
Section Width: 8.1"
Sidewall Height: 3.2"
Minimum Rim Width: 7"
Maximum Rim Width: 8"
205/50/17
Tire Diameter: 25.1"
Section Width: 8.1"
Sidewall Height: 4"
Minimum Rim Width: 5.5"
Maximum Rim Width: 7.5"
A 205/40/17 is going to give you more fender clearance if you are lowered. THe 205/50/17 is going to be closer to stock height.
Old October 14th 2002, 18:15
darren's Avatar
darren darren is offline
Re: tyre sizes again - 40 or 50 profile?
I thought you were using those fuchs?
As long as your not using cup 1s
darren
Old October 14th 2002, 18:21
hot66's Avatar
sold fuchs a long time ago
cup2's have been the plan for a while, have toyed with others but decided the cup2's followed the lines of my car better, I feel they look more organic
project in progress
Old October 14th 2002, 18:32
NYBugman1972's Avatar
Go with 40's up front. 50's could cause problems. You could run 50's out back, if you wanted to. Less clearence issues.
Mike Serrone
///BrooklynAutoRennen
Old October 14th 2002, 18:40
darren's Avatar
ah yes
I have rust on my bug to give it that organic look
Old October 14th 2002, 19:25
vert vert is offline
I'm running 40's all round for that lowered look and they are lots better for clearance too!
Old October 15th 2002, 09:10
If you have bad roads around your way go for 50s, 40 or lower are only for very attentive drivers. Why not go 1/2 way and use 45s.
Steve C
Old October 15th 2002, 14:22
hot66's Avatar
the roads in Yorkshire (UK) are very narrow, very twisty, full of potholes & usually not very smooth. I think I should Baja my cabrio instead
has anyone got any photos of wheels with 50, 45 or 40 tyres on?
Just so I can compare looks.
project in progress
