Old December 19th 2004, 11:40
Lurv Lurv is offline
Help with 944 Rear setup
I HAVE DONE A SEARCH!!! but didn't find the info...
I need to know what parts you need to do a bolt on to a 1303s.
as Im going to by it over the net I realy want a parts list pref with part #. what do I keep from the STD setup, what do I need to get from the porsche dealer?
thanks,
Old December 21st 2004, 03:08
Superman
[QUOTE=Lurv]I HAVE DONE A SEARCH!!! but didn't find the info...[QUOTE]
The info is there, over and over again
Old December 21st 2004, 08:51
danielzink's Avatar
I went up to the top of this page - to the search - and typed in
1303 944 brakes
just like that........and got 3 pages of hits.
Just as an experiment.
Dan
65 notch 2300cc type4
www.danielzink.com
Old December 21st 2004, 17:27
I got alot of post too but none that contain a parts list... I got alot of useful info but not what to order (in my case) from the porsche dealer...
most post are about front brakes and are answerd with "do a search"...
Old December 21st 2004, 18:33
Superman
Here are the posts, from a search in the brakes forum, that you should read. There is lots of information and I think the reason that you haven't found the exact list is because there are several ways to do this conversion and you'll have to make your personal choice.
http://www.germanlook.com/Forums/showthread.php?t=1896
http://www.germanlook.com/Forums/showthread.php?t=1804
http://www.germanlook.com/Forums/showthread.php?t=3855
http://www.germanlook.com/Forums/showthread.php?t=2881
http://www.germanlook.com/Forums/showthread.php?t=2203
http://www.germanlook.com/Forums/showthread.php?t=1703
Old December 22nd 2004, 00:17
Pillow's Avatar
Pillow Pillow is offline
If this is just for the rear it is so easy it will make you cry.
Get 944 rear brakes from swing plate out (you need the caliper mounting bracket outward). Install on IRS arm. Done.
http://www.pelicanparts.com/944/944_...3-85/Pic69.jpg
The only issue that should arrise is how to deal with the emergency brake cables. Since I have not done a Super you have to search on that one.
FWIW you should buy a cheap POS Haynes 944 manual to get an odea of how the brake system works. They are cheap... In all ways.
It is easier than you think. Do it. Do it. Do it.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old December 22nd 2004, 01:15
Superman
It is the exact same as the Standard (IRS) Bug.
Old December 22nd 2004, 01:24
Superman
Thanks Pillow. There you go Lurv, take the parts in the picture and bolt them to your axle. This is the simple method. The other two choices would be to bolt on the early steel 944 spring plate and trailing arm (for the camber adjustment) or another choice is the late aluminum arms...
http://www.germanlook.com/Forums/showthread.php?t=1993
Old December 22nd 2004, 05:48
Thanks Pillow!
just talked to the dealer and I think we got it all right thanks to your pic...
and yes, a porsche manual is in the mail from amazon...
Lurv
Old December 22nd 2004, 06:14
Superman
Those pictures can also be found on this German Look site:
http://www.germanlook.com/Images/Tech/Tech18I.jpg
http://www.germanlook.com/Images/Tech/Tech18J.jpg
Why the dealer? It's going to be aweful expensive! Used is the way to go.
Old December 23rd 2004, 00:29
Pillow's Avatar
I agree with Superman, go used on every part you can.
I think I bought a rear setup for $50 in poor condition. Then rebuilt the calipers, turned (resurfaced) the rotors and cleaned them, new e-brake shoes, and put on new pads. And a few misc gaskets and retaining pins.
On-line I like to use Pelican Parts as they are always easy to deal with. Never had a delay or wrong part issue.
Good Luck,
Adrian Pillow
Old December 23rd 2004, 10:39
agreed on used parts. why are you looking to the dealer? location and availability of used parts? you will see about 4x the pricing from a dealer.
regarding the parts list. i went through the same thing and like super said, there are soooo many options and variables across different models that there is no one parts list to document. and no one has spent the time to compile a matrix. may not be a bad idea for some one though. i will start a separate thread to see if people want to throw in.
