Old December 25th 2004, 14:44
flat flat is offline
17x7 wheels off my 1302
My car's gonna be in storage for a couple years, so I figure I should get rid on all the commodity items before they loose all their value, so:
*4 - 17"x 7"Tenzo ZT-6 wheels. Gunmetal finish. Dual bolt pattern, 4-100mm and 4-4.5"
*Very good condition, some curb rash on front wheels.
*+42mm offset
*2 bare rims, 2 with well worn (camber wear) 215/40 Yokoham Avid H4's.
*With center caps and hubcentric rings (56.1mm)
*C$700 /set (add T1 used front disks in 4-100mm patten for additional C$100)
*Matching rear brake kit (with e-brake) for additional $C400. Used only about 3k kms
See pics at:
http://www.thesamba.com/vw/classifie....php?id=133328
www.vdubengineering.com
Old December 28th 2004, 21:38
Alright,
$C750 for the wheels as described and the front rotors. Also, complimentary machining of your rear rotors/drums to the 4-100mm bolt pattern.
More info on the disks:
They are stock disks machined and studded(M12x1.5) for 4-100mm bolt pattern. They measure at 0.370" thick (New=0.374, Wear limit=0.315), so they are in very good condition. They are crossdrilled.
Any takers?
Old June 1st 2005, 23:28
I got rid of the brakes, but I still have the rims.
2 with 215/40 (heavy camber wear) and 2 bare wheels. $C675.
I can mount 2 very new 205/50's for an additional $C80 on the rear wheels.
Free machining of your brakes to match (studs extra).
Motivated seller.......
